Measuring actual welder amps
   / Measuring actual welder amps #1
bbrown4804
Bronze Member
Northern Colorado
1953 Farmall Super M
Being that my two welders are kinda old I got to wondering what the actual number of amps that is being put out? So how would I measure this? I weld anywhere from 20 amps to over 350 amps according to the selector dial.
Bruce
   / Measuring actual welder amps #2
A clamp meter to one of the cables should do it. While welding of course.
Now what would I look for in a good one without shelling out a ton of money?
   / Measuring actual welder amps #4
If you are measuring DC current make sure to get a DC amp meter. Fluke sells good electrical meters.
   / Measuring actual welder amps #5
Just look for a set of DC Tongs. (meter) Off brands are $30 top names are $300. Hook the tongs over the ground cable while welding..It will read output.. How curious are you? Hook up a 5/32 rod and if it lays a good bead...You're in the money on what ever you build.
   / Measuring actual welder amps #6
A clamp meter will tell you what amperage you are welding at if you are curious. If you are concerned with the output capability of the machine you would need a load bank. Your machine is rated 500 amps at 40 volts at 35% duty cycle and 575 amps max. Getting a clamp meter to read 400 amps while stick or wire welding may still have the welder at only 50 or 60 percent capacity.
(INOP) FORD 8N / 9N TRACTOR (A51247)
(INOP) FORD 8N /...
TEST YOUR BID BUTTON! (A51247)
TEST YOUR BID...
480/70R38 LOT IDENTIFIER 122 (A53084)
480/70R38 LOT...
KUBOTA KX080-4 S2 EXCAVATOR (A51246)
KUBOTA KX080-4 S2...
ASSET DESCRIPTIONS & CONDITION (A53426)
ASSET DESCRIPTIONS...
UNUSED WOLVERINE 66" BOLT ON PALLET FORKS (A51248)
UNUSED WOLVERINE...
