McCormick GX50 Update
   / McCormick GX50 Update #1
charleyfarmall
Platinum Member
Central Maine
I now have about 50 hours on the GX50 doing all kinds of farm chores. I have only good things to say about the way the tractor works. First, it is very well built, but I knew that when I bought it. The engine is very smooth as is the power steering. The cab + A/C has turned out to be fantastic especially in dusty hot conditions. It was also nice at the end of winter to be out of the cold and have heat.
My wife has buried it more than once in soft manure filled fields and the 4wd and locking diffs do wonders. The only draw backs are: I could use a full size frame for some equipment use even though I have the power, and at 5'11" and 170 pounds I am very comfortable but if you are taller or weigh over 200# I think the cab would be small.
My initial concern about the loader specs is unfounded. The loader performs far above what the say it does. I had no problems lifting a large piece of equipment (0ver1200#) hanging off the front of the loader to full height to load it on a truck the other day. I see that the current sub frame is better than the older Buhler 195 subframe too.
Glad I bought it.
Charley
Plowing, tilling, haying...
   / McCormick GX50 Update #2
Glad to hear it. With the hot weather here I have been dreaming of a cabbed GX50 myself.
   / McCormick GX50 Update #3
Those McCormicks are tough looking and nice looking tractors. I drive by a dealer lot in Washington NC pretty often and usually have to watch crossing the white line while I gawk at the new stuff. Glad to hear the tractor is performing well. By the way, where are they made?
Jim
2003 Farmtrac60
   / McCormick GX50 Update #4
I know they have a plant in Doncaster England. (not sure the spelling or exactly what models are build there).
   / McCormick GX50 Update #5
I was actually helping a friend today do some haying with a CX75 pulling a square baler and hay wagon.
2004 Ford F-250 Pickup Truck (A50323)
2004 Ford F-250...
2007 BobCat S175 Skid Steer (A52384)
2007 BobCat S175...
2020 Featherlite Aluminum Stock Trailer (A52384)
2020 Featherlite...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52748)
John Deere 6105E...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A52748)
2022 New Holland...
