McCormick Deering OS4
   / McCormick Deering OS4 #1
FH50
Wilmot, N.H.
Hi everyone, this is my first post, and I would like to say that I like this forum it has everything you need you just pick a categorie.
I will be picking up a McCormick Deering OS-4 very soon, and the only major thing wrong is the clutch. It is called a Rockford Over Center Style hand clutch. The clutch is ceased, and on of the parts is cracked. I need to know where to get pats, part diagrams, and part #'s I also need to know which way is the handle to engage the clutch supposed to be in when engaged vs. disengaged? Foward or back? Any help is greatly appreciated
Thanks in advance,
Ryan
   / McCormick Deering OS4 #2
Did you figure it out & get it going?
Thanks for asking, and yes, i had it running this summer, and i had the clutch working fine until the friction disk broke and it went into pieces, and built up behind the clutch housing and cracked the threaded clutch housing. I will post pictures later.
6 ft. Rotary Cutter (A53117)
6 ft. Rotary...
2018 CATERPILLAR 950GC WHEEL LOADER (A52705)
2018 CATERPILLAR...
2025 CFG Industrial KKT(A)27 (A50123)
2025 CFG...
2121 (A51244)
2121 (A51244)
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
2015 Hooper T/A Trailer w/Mounted Foaming System (A53117)
2015 Hooper T/A...
