John Dougherty
Bronze Member
I have a Mahindra Max 28XL with 20 hours on it. My boom control on the MB63 started to get slack in it and the BH would not apply much downward 'dig' pressure and would jerk back into the stowed position on retraction of the lever. Upon closer examination of the valve body I discovered that the cap that fits on the bottom of the valve body below this particular spool was missing. The manual that was supplied shows a plug as opposed to a cap. All of the other 'caps' are in place and the other functions work as they should. It appears that there is a positioner that is supposed to be ahead of the plug/cap according to the expanded view in the manual. When I insert my finger into the bottom of the valve body where this spool resides I can feel the spool move up and down when the lever is actuated (tractor not running). All is missing below the spool (or plunger as I call it). Has anyone else had a similar problem? Thanks.
