Max/Mitsubishi S3L Valve adj.
   / Max/Mitsubishi S3L Valve adj. #1
doneill127
CT
Mahindra Max
My owners manual does not show any recommended valve checks or adj. But the MHI Owner manual and Service manual recommends checking them every 500 hrs. So after finishing up an oil change decided I'd check mine(490 hrs) Recommended clearance is .010. Found one at .002, a couple at .006 and only one was at .010. So I set them all at .010.
This is just a heads up that you may want to check them at some point. Very easy to adjust old school locknut and screw driver. Only tricky part is it's a 240 degree rotation of the crank to the next TDC because it's a 3 cylinder.
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A52748)
Heavy-Duty...
20' Inline Feed Bunk (A50515)
20' Inline Feed...
2020 Hitachi ZX60USB-5N (A47384)
2020 Hitachi...
IH Farmall 706 Tractor (A50514)
IH Farmall 706...
Army Semi Trailer (A50774)
Army Semi Trailer...
