MAX FEL QDs
   / MAX FEL QDs #1
doneill127
CT
Mahindra Max
I posted a thread over in the hydraulic section looking to change the style of the loader QDs because a couple were leaking from my beating on them to releive the residual pressure on the loader side. Ended up having a difficult time finding replacements but learned a bunch about fittings and thought I'd share. Believe this only applies to the max series with FEL that came from KMW.
Managed to get the Faster spec sheets and found out the NV 14-38 SAE is a 1/4" ag fitting with 3/8"SAE threads which are 9/16 -18UNF with ORB(o ring boss) It is a pretty common size. But the only Faster NV size that is ISO 7241A is the 1/2 size. So if I wanted to go with something other than Faster I'd have to switch both male and female. Turned out to be a none issue found correct Faster on Amazon for $25 ea. Little steep.
Thought I might save someone else some trouble.
2016 Nissan Altima Sedan (A50324)
2016 Nissan Altima...
2005 Mitsubishi Lancer ES Sedan (A51694)
2005 Mitsubishi...
2008 Ford F-150 Ext. Cab Pickup Truck (A50323)
2008 Ford F-150...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52748)
2024 Ford F-350...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
Kubota B7100 Tractor (RUNS) (A50774)
Kubota B7100...
