Max 28xl question
/ Max 28xl question #1
Bungiex88
Dysart
73 Farmall 574, 2016 mahindra 1533
Pulled a hydraulic/transmission filter and fluid change on a max 28xl this weekend. Quick question the fill for the hydraulic and transmission fluid is all the same correct? I’ve never worked on a hyrdrostatic before and the book made it seem like it was all one fill if you drained each final drive and the transmission plus the hyrdraulic filter and the transmission filter am I correct????
/ Max 28xl question
The book didn’t make it super clear it would just say see transmission fluid change for one and the other said see hydraulic fluid change not to sure
/ Max 28xl question #3
My tractors 2815 HST and the transmission all share the same fluid, you should check the level at the HST dip stick.
So to your question yes one fill.
Won't hurt to change your front axle fluid also, gear lube per manual, assuming
that you live in a warm area.
/ Max 28xl question #4
Theres also several plugs to take out underneath to get all the fluid out. Seems like there was 3 under my 26xl if i remember correctly.
/ Max 28xl question #5
My tractor has has 6 drain plugs on the transmission and only found all of them by looking at the remove engine section of the service manual, owner manual didn't show everything the first time.
First time changing the oil I new something was wrong as I didn't use enough fluid, it supposed to takes 8.2 gallons.
/ Max 28xl question #6
My 26xl has 3 drain plugs, and yes, the Hydraulic and Hydrostatic fluid are one. Check and fill on the floor in front of the seat.
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
2018 Freightliner Thor Venetian 400XCR A40 41ft. Class A Motorhome (A59231)
2018 Freightliner...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2017 Ford F-150...
2007 Ford E350 (A55973)
2007 Ford E350...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
Hydraulic Stump Grinder Mini Skid Steer Attachment (A59228)
Hydraulic Stump...
