Max 28 rotary cutter
   / Max 28 rotary cutter #1
John32369
New London NC
Max 28
What size rotary cutter can I use behind a max 28? I have a 5 foot finish mower, and was just wondering if a 5 foot rotary cutter would work too?
   / Max 28 rotary cutter #2
Rotary cutters are usually heavier and require more HP than a finish mower of the same width.
The rule-of-thumb is 5 PTO HP per foot of cutting width. Most manufacturers offer light-, medium-, and heavy-duty cutters with minimum HP requirements increasing with weight.
Your best bet is to check the HP requirements provided by the various manufacturers.
Steve
   / Max 28 rotary cutter #3
It will also depend on the speed you want to mow and what you are mowing.
In order to minimize the number of passes to mow between the blueberry bushes I am running a 6ft brush hog. Of course my travel speed is barely walking.
It still cuts my time in half compared to the way it was done previously.
   / Max 28 rotary cutter #4
I intend to buy one for mine. From my research it will run a 5 foot, but I plan to buy a 4 foot because I have limited storage room.
I'm probably going to go with a 5' mower. I'm getting it to use at my parents place and if its too much for the Mahindra, my brother has a MF 230 that I believe can handle it.
   / Max 28 rotary cutter #6
I have a 3016 and it looks like the 28 has the same pto HP. If that is correct, your 28 should handle a 5 ft no problem.
   / Max 28 rotary cutter #7
It will handle a 5 no problem... Know a guy pulling a 5ft with a 2015 Mahindra that actually does it well also
   / Max 28 rotary cutter #8
I have a 5" rotary cutter behind my Max 28 and it has never really even strained the engine at all and I have run it through some pretty heavy brush.
   / Max 28 rotary cutter #9
I don't know how big the cutter I have is (either 4 or 5, didn't measure it), but only drags things down when I back over relatively large brush (think small trees). It doesn't have traditional bushhog 'blades' on it though, more along the lines of hinged 3/8 to 1/2in lawn mower blades. I discovered this when the stump jumper retention nut came off and it all came out from under the cutter ($200 implements maybe should be looked over a little closer ;) I checked oil, fixed a couple small things and then took it out to the back of the back 40 for a test run and it did well, so I didn't think to check up underneath). No damage, but it made a helluva racket for a second, then everything got smooth and quiet..
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
Year: 2012 Make: Honda Model: Accord Vehicle Type: Passenger Car Mileage: 91,438 Plate: Body Type... (A51694)
Year: 2012 Make...
2011 Manac 36245B30 45ft T/A Walking Floor Trailer (A50323)
2011 Manac...
2013 ISUZU NPR STAKE BODY TRUCK (A52577)
2013 ISUZU NPR...
2006 Ford Expedition 4x4 SUV (A50324)
2006 Ford...
