Max 28 rear wheels slipping
   / Max 28 rear wheels slipping #1
rdwyer
Guilford, CT
2015 Mahindra 28XL Hydro
Hi all. I noticed today as I was driving in 2 wheel drive up my paved (but steep) driveway that the rear wheels basically felt as though the shaft that drives them was slipping. I dropped into low and got a bit more traction but ultimately the same thing...I could not get up the driveway. I could feel and hear the rear end trying but no luck. I dropped it into 4 wheel and the front wheels had now problem pulling me up. Fluid in the hydro is clean a full.
Could this be from the driveshaft that runs to the back of the tractor?....the rear axle itself?....hopefully not the hydro unit?!?!
220 hours on my max with all fluids and filters done in April.
Thanks,
由ick
   / Max 28 rear wheels slipping #2
Did you have a full bucket of dirt? do you have any rear ballast ? ..........
   / Max 28 rear wheels slipping #3
Did you look at the rear wheels to see if they were losing traction? I mean, was the wheel spinning and you weren't moving?
Empty bucket, tires are filled with ballast and a 3 point chipper on the back. It feels very similar to a clutch slipping in a car or a belt slipping on a lawn tractor.
Tires were not spinning...I was on my paved driveway. Maybe tomorrow I will drop the drive shaft to see if the spline are stripped.
   / Max 28 rear wheels slipping #6
A lot of times when this happens, the tire is slipping on the rim. It can be exacerbated by low tire pressure and having filled tires.
   / Max 28 rear wheels slipping #7
This happened to me while moving snow a couple winters ago. I've put a couple of aligned dots of paint on the rim and tire so if the slippage occurs again I'll know the tire pressure may be low.
Bingo! Right rear tire is a bit low on air and the rim keeps turning but the tire doesn稚. Any harm in topping it off with air if it痴 a ballast filled tire?
   / Max 28 rear wheels slipping #9
Of course there is no harm, that is what you are supposed to do! You should be checking the tire pressure and topping it off with air at least seasonally, if not more often (regardless if it has fluid or not). Tractor/equipment tires like to leak more than typical car/truck tires, probably because they are so stiff and the rubber is thicker with sloppier tolerances. So it's important to keep an eye on pressure frequently. If it gets bad you can roll a tire off the rim and then you've got yourself a real pickle, especially if the tractor is somewhere out in the boonies.
   / Max 28 rear wheels slipping #10
By the way, fluid filled tires are only filled 3/4 (about to the top of the rim) with fluid and the rest is air. That is necessary to retain compression and cushioning of the tire. It's that 1/4 air volume that is important to maintaining the pressure, bead sealing, and load carrying capacity of the tire. The fluid simply takes up volume and adds weight, but by itself it can only generate hydrostatic pressure at the bottom of the tire. At the top you need the proper air pressure to set the overall tire pressure to specification and let the tire perform like it's supposed to.
2018 Ford Escape SE AWD SUV (A50324)
2018 Ford Escape...
43013 (A51691)
43013 (A51691)
2017 John Deere Z970R (A50121)
2017 John Deere...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
1994 Mack CH613...
Airco Tig Welder (A51691)
Airco Tig Welder...
Towable Orchard Sprayer (A51691)
Towable Orchard...
