Max 26XL mower deck issues
   / Max 26XL mower deck issues #1
tmcj
Imler, Pa
Mahindra Max 26XL
I've had a few issues with my mower deck caster set up since I bought everything new last spring. Late last summer the front caster shaft somehow got bent a little. I never hit anything with it but just normal mowing the yard with slight hills, typical turning etc seemed to be too much for it. It wasn't bent bad but just enough that it wouldn't slide through the collar to drop the deck to drive over it and remove it. Considering that this shaft is $132 for a new one :confused2: I took it to my work's machine shop and had them straighten it for me, which has held up through this year so far. But now the problem is the upper retainer ring that is supposed to hold the caster in place on the shaft keeps popping out of its groove and letting the shaft move up and down, and it has been rubbing the caster wheel enough to be wearing a flat spot on it, and also grinding off the metal of the shaft, almost to the point of the lower retaining ring not having enough material left to hold it on.
This is my first true disappointment with my Mahindra tractor and equipment. I just think that this shaft and caster design is really poor. I have a solution to the upper retainer ring issue, which is to drill another hole for a 3/8" clevis pin in place of the retainer ring. This should never fail unless the pin were to come out. There is no way I am spending $264 to replace both shafts for the deck. I can easily get a 1" round bar stock drop from work and make my own 8 1/8" long shaft with a few holes and ring groove in it for practically nothing but a favor from a buddy in the machine shop.
I guess I'm just venting some and wondering if anyone else has had similar problems with the deck casters and what they may have done to fix it, other than spend a ridiculous amount on new ones.
BTW, I don't mow really fast either. I have the HST model and I am typically at full speed of low range at most. Anything faster just seems like asking for more trouble. I also keep the deck height set to the highest setting on the caster assembly so it's not really low to the ground. I keep the 3 pt adjusted to where it doesn't hold up the deck at all and the casters support the deck and keep it level, as it is designed to work. I'm just disappointed that seemingly normal usage is causing these issues already. I do not abuse any of my equipment and try to stay on top of any possible problems like this.
   / Max 26XL mower deck issues #2
Sorry to hear about your mower deck. I have the same set up. Mowed all last season and this year too. No issues at all. I mow 5 acres of mostly flat but some small hills. I will be looking closely at my casters and posts from now on.
   / Max 26XL mower deck issues #3
There are two ways to mow with the 26XL deck: one let it drag on the gauge wheels or two suspend the the deck with a 1/4" gap between the gauge wheels and ground. I was told by my dealer to only drag the deck if I had a extremely smooth lawn, so I use the suspended method and have had zero gauge wheel issues. As you have found out the gauge wheels are expensive, so why put undue stain on them? If you use the suspended method I highly recommend the John Deere deck gauge to set the deck height and deck level each time you mow, it only takes five min and ensures a perfect cut. Search John Deere deck gauge on Amazon to find the tool. Note: this tool is the best thing I have found to calibrate any riding mower deck.
   / Max 26XL mower deck issues #4
I have same set up and mow alot, 3rd year coming up. Never an issue with deck or tractor. I mow at highest setting, so wheels are on ground but I do keep an eye on them. I am always taking deck off and on, and always inspect everything closely.
It is almost that time of year again here in Pa and I will soon start getting ready for the mowing season. I have considered doing the suspended set up and that gauge looks like it would be pretty handy. I'll have to try it out. Thanks!
2012 Ford F-150 (A50120)
2012 Ford F-150...
2008 Ford F-250 (A52748)
2008 Ford F-250...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
2018 HINO 268  NON CDL 26FT BOX TRUCK (A52141)
2018 HINO 268 NON...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
