Max 26xl and 28xl what to look for on used tractors?
   / Max 26xl and 28xl what to look for on used tractors? #1
monkeyman9
Ford
Any common issues or problem areas I should be looking for in used max26xl and max28xl tractors?
   / Max 26xl and 28xl what to look for on used tractors? #2
I haven’t seen anything other than something about a starting issue. Maybe a hidden fuse or something.
This was more of knowing where the fuse is than anything else. Overall I hear good things about those models- probably a good choice.
   / Max 26xl and 28xl what to look for on used tractors? #3
Water/moisture can damage connectors in the wiring harness, causing a range of issues, including taking out the fuel solenoid, which will make the engine quit and/or fail to start.
Anything I can specifically look at for this? Connectors I should unplug and look for corrosion?
   / Max 26xl and 28xl what to look for on used tractors? #5
It may have been that fuel solenoid instead of a fuse.
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
2009 Chevy Silverado (A47384)
2009 Chevy...
10ft Fork Extensions (A50322)
10ft Fork...
Woods F21D Zero Turn Mower (A50514)
Woods F21D Zero...
Hydraulic Grapple Bucket (A47384)
Hydraulic Grapple...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
