Max 26 front bucket weight ?
   / Max 26 front bucket weight ? #1
nosurprise
Panama city FL
max 26xl
Anyone know the weight of the 26 max front bucket. Looking to purchase ssqa pallet forks. One weighs 320 the other is 82 lbs. lighter. The brand that weighs more is actually about 150 cheaper. I'm trying to justify spending the extra money on the lighter forks.
   / Max 26 front bucket weight ? #2
Unless you knowingly want to reduce your capacity by 82#, wouldn't the lighter forks make more sense? Especially on a small tractor you should be counting your pounds when it comes to capacity.
The Max has a strong loader, perhaps too strong for such a small tractor. The weak link is not the loader, it's the small footprint of the tractor. So be careful lifting/moving heavy loads. Will 82# matter, or tip you over the edge? That's probably the objective way to look at it.
No just trying to determine if the front bucket weight is close to the 310 lbs. 310 is the weight of the heavier forks
   / Max 26 front bucket weight ? #4
The Bucket weight is about 135 lbs on a Max28 Pin on bucket. It is a relatively small flimsy bucket. I added about 40 lbs of reinforcement.
I'd go with the lighter forks. The loader curl capability is not well matched to its impressive lift spec and curl force is important with pallets.
Thanks I will take your advice. I did not realize the bucket is so light. I agree the curl does not seem to match up well to the lift. Even with the small bucket if I go in deep with the bucket it will not curl out with a full bucket unless you back out. But as far as power curling through it, forget it. Maybe raising system pressure and relief adjustments will help. Not sure, I just expected a little more out of it. I am convinced that it is not performing per literature specs though. Thanks for the input.
   / Max 26 front bucket weight ? #7
Weak Loader Curl Possible Solution For the Max28
Don't know if you have seen this thread or not- food for thought regarding your loader curl.
Yes, thanks for the link to the thread. After inspection of the max 28 loader it appears to be a little more stout than that on the new 26 curved model. Do you know if anyone sales upgraded cylinders fitted for the max 28 and 26. Also, is raising system pressure and relief adjustments working for anyone out there. I don't think I would attempt a job like Mike did to his 28, wish there was a shop here that does the 1526 cylinder upgrade. Any shop recommendations in the SE part of the country? Alabama, FL, GA. Thanks for any input.
   / Max 26 front bucket weight ? #9
The Max 26 loader uses 3/4" or 19mm or 20mm pins. I'm not sure of the exact size. in any case they are smaller than the MAX28 or 1526.
So to use the 1526 Cylinders, you would either have to open up or cut off and weld on new bushings or make a sleeve so the smaller pins would work.
At that point it may be more cost effective to try to modify a set of 1.5" bore cylinders with 3/4" dia pin ends for the correct retract extend distance.
The Max28 curl cylinders were a piece of cake and a fraction of the cost vs. doing the rebuild of the BH swing cylinders on my L39 and upsized the L39 Loader Cylinders. The L39 BH swing cylinders got damaged, and the loader cylinders were starting to get blow by after 2000 hours of hard use, so rather than just rebuild them, I modified the loader by increasing the cylinder bore sizes just 5mm. The Loader on the L39 is really stout, I just need to be careful with the front axle. The L39 needs both its wheel weights and the BH for counter weight. There are not to many CUT sized tractors that can lift near two tons on a pallet.
Yes I think it is 20mm pins either way that makes it a more complicated fit. Before you swapped cylinders by chance did you try raise system and relief pressure? I see you used a washer to shim. Was that post cylinder swap or before? If before was there a noticeable difference?
2 tons lift on the L39? Good grief that things in beast mode.
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
2015 Revere Shasta 27DB 5th Wheel Travel Trailer (A51694)
2015 Revere Shasta...
Sky Trak 10054 Legacy 10K Telehandler (A51573)
Sky Trak 10054...
