My coolant reserve bottle is below the Low line. Do you add the coolant to the coolant reserve bottle or through the radiator ? Does Mahindra provide a Mahindra brand ethylene glycol coolant ? Thanks
Depends on if by low you mean empty. If its empty low I would add straight to the radiator. Remove the cap while cold and start the motor and add as the fluid goes down. If just the over flow bottle is low fill it to the cold mark and check it after your engine is warmed up awhile add as needed.
