Material for Material Collection Filter / Bag?
   / Material for Material Collection Filter / Bag? #1
keeney
Veteran Member
Minnesota
JD 4100 HST
Anybody know of a good source for the heavy nylon woven mesh fabric that is used for grass-catching bags?
I need to find something that will keep the leave and clippings IN the material colleciton system I am building without clogging.
To quote Mr. Dyson, "It loses suction...".
- Rick
   / Material for Material Collection Filter / Bag? #2
I would like to bet that fiberglass screening available at most hardware stores like Ace might work for you. I purchased some yesterday to use to skim watermeal off our pond and was amazed at its strength. a 3'X4' was less than 4 bucks.
On my leaf-vac project, I have now swapped out the 7" diameter air-vents (with bird screen) for a much larger surface area covered with polyester window screen. The extra heavy "Pet-Proof" variety.
The screen is over a 18 x 24 inch area on the top of a plywood box that is screwed onto the lids of the trash cans. The interior 18" of the lids and lower plywood are cut away so the clippings can drop from the box into the cans.
The blower discharge is directed into this plywood box from one end by a metal deflector chute.
It works pretty good - I vac'd about 1/2 acre in under an hour - most of the time spend emtying the dual 44-gallon trash cans. It wasn't so much the leaves, but I was also cutting quite a bit of grass clippings. The yard has gone several weeks waiting for this project to get completed!
I plan to make some changes to make getting the cover on and off quicker. The main change will be to add a hinge so it can just flip up in place and then back down without lifting it completely off. The other change is to move the trailer I am dumping the clippings into closer to the area being mowed.
The other issue is that the air is now discharged straight up. Along wiht the dust. OK as long as you go forward, but any backing up and the driver gets covered. I will need to add an additional deflector over the top to direct the dusty air away.
This discussion will make more sense to the readers here when it gets light out and I can take some photos.
- Rick
SKID STEER BUCKET (A52472)
SKID STEER BUCKET...
378812 (A51573)
378812 (A51573)
2011 KOMATSU PC160LC-8 (A52472)
2011 KOMATSU...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A53472)
2015 RAM 5500...
2024 John Deere 6120E MFWD Tractor (A53342)
2024 John Deere...
