massy 231 3pt lift
   / massy 231 3pt lift #1
liquidwrench
a friend of mine asked me to take a look at a massy 231 he just bought. the 3 pt has 2 levers but the decals are too faded to read so we're unsure which lever controls what? moving them up and down the lift acts crazy. if you go up, sometimes the arms will drop.! is that how they're supposed to be? anybody have a manual or a link to a web page with info on it? or just plain ole advice? thanks in advance.
   / massy 231 3pt lift #2
1 s draft, the other is position control. Position control sets your lift arm hieght, draft sets the sensitivity of the lift arms. As you found out, you can get different results by moving the levers in various positions. If you have a rear pounted implement that is pulled thru the ground, you will want to set the draft hi enough so it will lift the 3 point up a little automatically when you hit a hard spot so as not to bog the tractor down to much. Once you get thru the hard spot the 3 point will lower on its own. If you have a rear mounted implement that just sits on top of the ground like a blade or tiller, you don't need the draft. An owners manual will do a good job of explaining how it works.
   / massy 231 3pt lift #3
Basically, to use the inner Position control, the draft control lever is set all the way up, the opposite is true when using Draft control.
thanks for the help guys.
2006 Toyota Tundra 4X4 Pickup Truck (A50323)
2006 Toyota Tundra...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2012 JOHN DEERE 310SJ BACKHOE (A52472)
2012 JOHN DEERE...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
J and L Cargo Express Shadowmaster Enclosed Trailer (A52748)
J and L Cargo...
