massey65 lower radiatoe hose
   / massey65 lower radiatoe hose #1
M E Cook
Bronze Member
SE TN
ls tractor
J havs a mf 65 with perkins diesel lower hose was rubbed thru by v belt it is a close fit ordered new hose any ideas on how to prevent this in the future ???? thanks
   / massey65 lower radiatoe hose #2
I don't have any experience with your engine/chassis combination. However, I had to be careful on my Ferguson TO-35 with the same issue. I found that variables I could play with were the length of the lower hose , and use of a corrugated ( rippled outer surface) hose for more flexibility. The corrugated hose may or may not be a good answer. If it's a long hose, some people also worry about the lower hose collapsing if there's no corrugation or inner spring. If all else fails, you can also move the hose a small distance out of the way with tie wraps , rope, or a metal shield. I finally settled on a corrugated hose that was not a " factory" replacement, but had the correct diameters at both ends but was a bit longer than stock.
I'm going to build a sheild to slip over hose to squeeze it a little to give some clearance from the belt
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2015 Tiger Trailers Inc. Gooseneck T/A Enclosed Trailer (A51692)
2015 Tiger...
2015 Case 580N EP Loader Backhoe (A53117)
2015 Case 580N EP...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2015 Ford Transit 250 Cargo Van (A51692)
2015 Ford Transit...
