Massey TO35 6volt
   / Massey TO35 6volt #1
Marywood1
Massey Ferguson TO35 6volt
Have replaced starter motor,coil,voltage regulator,starter switch,new battery. Cannot find short , battery keeps draining. Any ideas
   / Massey TO35 6volt #2
Find a very small 6 volt bulb, like from a 6 volt flashlight that uses the single square battery. Or borrow one from the dash on the tractor. Unhook the battery cable, either positive or negative, doesn稚 matter.
Rig up some leads on the bulb so you can hook it between the battery post and the disconnected battery clamp.
If you have a drain, the small bulb should glow.
Go around and unhook wires, pull fuses, unplug connectors, one at a time and watch the bulb. If it stops glowing, you have found the drain. Reconnect each wire or circuit before unplugging the next one.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2019 FREIGHTLINER...
2020 Caterpillar 420F2 4x4 Extendahoe Loader Backhoe (A50322)
2020 Caterpillar...
Bobcat 3400 ATV (RUNS) (A50774)
Bobcat 3400 ATV...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
1996 Carolina Skiff 19ft Fishing Boat with Boat Trailer (A50324)
1996 Carolina...
