massey mf135
   / massey mf135 #1
2savvy4
Hi, i,m a new member to the TBN. I bought a 73 massey mf135 with a perkins diesel and used it a few times with a rotary mower. It worked fine for a while then i noticed the exhaust started getting black and it started losing power. I shut it off and had a hard time getting it started again but when i did i noticed it was spitting air back through the air cleaner. Someone told me it was a stuck valve so i took it apart and took the valve cover off and all the valves are moving fine. any suggestions from anyone? Do i need to pull the head?
   / massey mf135 #2
Before pulling the head, I think, I would check the injectors and the pump. Ken Sweet
   / massey mf135
would that cause it to soot in the air intake hose?
   / massey mf135
   / massey mf135
i ended up pulling the head and found a blown head gasket, apparently someone ran it hot, i took the head in and had it plained and magnifluxed and put it back together and it works like a champ!
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2018 BOBCAT T590 SKID STEER (A51246)
2018 BOBCAT T590...
Skid Steer Sweeper Attachment (A51573)
Skid Steer Sweeper...
Cat TH407C Telehandler (A52748)
Cat TH407C...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A52748)
UNVERFERTH 330 8...
Ford Tractor (A50120)
