Massey MF 40
   / Massey MF 40 #1
scotsslant
yucca valley, ca
Massey Ferguson MF 40
Greetings,
Help!
I have a Massey MF 40, probably about 1970's.
I need to check power steering fluid.
As near as I can figure it is located on the right side of the engine and is shaped like a machine gun drum magazine that was on a Tommy gun. (Don't know how else to describe it).
Anyway, if that is the power steering reservoir, there is a nut on the top of it that I guess you remove to fill the reservoir.
Is this correct?
If yes, how do I check the level of fluid and is it acceptable to use the same fluid I use for the hydraulics for the power steering?
Thank you very kindly!
Case IH Precision Disc 500T (A50120)
Case IH Precision...
1993 INTERNATIONAL 9700 TANDEM AXLE CAB OVER (A52577)
1993 INTERNATIONAL...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A50323)
2015 Ram 5500...
2007 Kenworth T800 Truck, VIN # 1XKDP4TX97J190550 (A50323)
2007 Kenworth T800...
2017 Club Car Carryall 300 Utility Cart (A51691)
2017 Club Car...
6-CNH Rear Tractor Weights (A50774)
6-CNH Rear Tractor...
