Massey MF 1250 trouble
   / Massey MF 1250 trouble #1
masseytrouble
Massey Ferguson MF 1250
My MF 1250 has been making noise when in 4 wheel drive. I don't use 4X4 unless I'm stuck. This past weekend, I engaged the rear differential lock and when I applied more throttle, there was a bad grinding or metallic sound coming from the rear end. Yesterday, when I was on concrete, in 2 wheel drive, turning a circle to the right, I again heard the grinding or grabbing noise in the rear end. Then later when I attempted to activate the PTO, nothing happenedd other than the PTO light came on. The PTO worked fine the day before. The tranny on this machine is a 16 speed shuttle shift. There are about 900 hours on the tractor. Any advice or suggestions? Thanks.
   / Massey MF 1250 trouble #2
i think the frist thing you should do is drain the tractor fluid. there is a filter on the left side. remove it and see if its damaged. if its damaged then the drive shaft has been driven through the rear housing. the tractor will have to be split to fix.
Thanks. wrenchturner suggested I do the same and look for metal parts. I contacted a dealer, they recommended I remove the top cover on the rear end after draining the fluid, and take a look inside the rear end. What do you think it would cost to rebuild rearend?
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
3014 (A50657)
3014 (A50657)
2001 GMC W4 CRANE TRUCK (A51222)
2001 GMC W4 CRANE...
1981 CASE 580D BACKHOE (A51242)
1981 CASE 580D...
2014 Dynapac CC4200 Tandem Vibratory Roller (A51039)
2014 Dynapac...
FORD COBRA REPLICA RACING CAR (A51222)
FORD COBRA REPLICA...
