Backhoe Massey-Harris 44(6)
   / Massey-Harris 44(6) #1
d16542
York, PA
Massey-Harris 44(6)
I have bought my first tractor, a 1951 6 cylinder gas Massey-Harris. It does not have a 3 point setup on it. Are these typically available as a bolt-on or bolt-on with minor modifications?
Then I would like to install a backhoe. The tractor has an engine driven hydraulic pump that runs the loader, a side PTO for a belt and a rear PTO.
What should I be looking for with regards to 3pt and backhoe? Thanks in advance!
   / Massey-Harris 44(6) #2
I'd build a sub frame for the BH, Wouldn't fit a 3PT, they were basically an after thought on 44Ks, 744D &745D, these would similar to your 44s(6).
If your engine driven pump is capable of working a BH I'd tap into its system, if its not you could use a PTO or BP drive set up.
If it is already fitted with a FE loader, the addition of a BH would make it into a very useful unit.
Thanks for the info.Should I be looking for a BH first and then design a subframe around that? Or are there certain ones I should look for? (or stay away from?)
   / Massey-Harris 44(6) #4
d16542;388550 Should I be looking for a BH first and then design a subframe around that? [/QUOTE said:
I'd buy or build the BH first.
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
KUBOTA KX080-4 S2 EXCAVATOR (A51246)
KUBOTA KX080-4 S2...
Spartan Pierce Foam Pumper Training Fire Truck (A51692)
Spartan Pierce...
2024 JOHN DEERE 8R 280 LOT NUMBER 8 (A53084)
2024 JOHN DEERE 8R...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
