Massey GC2400 electrical issue, won't start
   / Massey GC2400 electrical issue, won't start #1
Zane Marshall
Green Creek, NC
Massey Ferguson GC2400
I have a Massey Ferguson gc2400 and I haven't been able to get it to start since Jan. The battery is fully charged, all fuses are good. If it sits for a while (a few hours), when I turn they key on, it takes about a minute before anything happens. Then the gas gauge will slowly start to register and the lights will slowly come on, followed by the fuel pump clicking slowly at first, then almost normal. When I try to start it, I hear a "ping" sometimes at the solenoid. I checked the wire at the starter and it is getting 12.5 V when everything seems to be "hot" (hearing the fuel pump, all lights on etc). I've traced most of the wires and don't seem to see any corrosion or signs of a short...If you suggest I try to start it straight from the battery to the starter, please advise me on how to do this. I'm a bit weary to do this since it says right on the solenoid "Start only from drivers seat". Any advise would be greatly appreciated!
   / Massey GC2400 electrical issue, won't start #2
Welcome to TBN. What makes you know the battery is GOOD, not just reading 12 Volts? Have you load tested the battery?
   / Massey GC2400 electrical issue, won't start #3
This problem has arisen in several 2300 series tractors, and was traced to corroded, and or broken wires on the back of the ignition switch.
2022 JOHN DEERE 331G LOT NUMBER 99 (A53084)
2022 JOHN DEERE...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
378643 (A51573)
378643 (A51573)
2014 FORD F-550 SUPER DUTY SERVICE TRUCK (A52472)
2014 FORD F-550...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
