Massey GC2310 Serial #JPA23431 HYD Problems
   / Massey GC2310 Serial #JPA23431 HYD Problems #1
XPA Farmer
Crystal River, FL.
Massey GC2310
Started this thread in hydraulics, had some views but no help. read a lot of post on this tractor but not sure if it is the same problem. loader and backhoe slowed down suddenly but it steers and drives fine. When you shut the machine down for a few minutes it acts like it looses it's prime (loader and backhoe won't move and the pump makes a lot of noise ) but will come back to life slowly. oil level is ok . took the filter off and didn't find a lot of metal in it when i dumped it out. put a gauge on the loader ports and it's putting out #1650 and the break off is #1950 (after i took off the loader and backhoe). I'm looking for a little help on weather you think it's a valve stuck or the pump is bad before i tear it down. also i found conflicting info on the serial # and year of the tractor. if it's an 05 it's probably the pump. (was told it was an 08 when i bought it with a little over 400 HRS.)
Wayne
2006 Acura RL Sedan (A51694)
2006 Acura RL...
2021 Simex TFC 400 rotary cutter, like  new (A52384)
2021 Simex TFC 400...
Doosan P250 Trailer Mounted Air Compressor (A53117)
Doosan P250...
2019 Bobcat 3400 4x4 Utility Cart (A51691)
2019 Bobcat 3400...
2017 FREIGHTLINER CASCADIA SLEEPER (A53426)
2017 FREIGHTLINER...
