Massey Ferguson GC2610 excessive pto shaft movement and oil leak
   / Massey Ferguson GC2610 excessive pto shaft movement and oil leak #1
renegade1958
Boundary Creek, New Brunswick, Canada
GC2610 TLB
Hi Everyone. I have a Gc2610 and have a oil leak at the rear pto shaft. There is a lot of up and down movement of the pto shaft and I was wondering if there is a way to replace the shaft bearings without taking rear end apart.
   / Massey Ferguson GC2610 excessive pto shaft movement and oil leak #2
Not familiar with that tractor. But with that said. Does the transaxle have a rear cover that bolts to the transaxle case surrounding the PTO shaft?? Such as the example in the attached picture?? If so, then yes, the bearing and seal can be replaced from the outside. If not, the transaxle assembly will have to be disassembled for repair.
   / Massey Ferguson GC2610 excessive pto shaft movement and oil leak #3
Yes, you can replace the bearing(s). There is two bearings.
You have to remove the rear cover plate. It has a seal for the PTO shaft replace that as well.
There is the PTO drive gear and a bearing on either side of it. Most likely will need a bearing and shaft pulled to get those bearings out if they a pressed in or they may slide out rather easy if they are worn. Make sure to drain the hydraulic fluid first before removing the rear PTO plate.
Rear Cover Oil Seal - 4264929M1
Outer Bearing Closest to Rear Cover - 6240858M1
PTO Shaft / Gear - 6254727M1
Inner Bearing - 6240863M1
Diagram Here
Object moved
Drivetrain System > PTO Clutch
   / Massey Ferguson GC2610 excessive pto shaft movement and oil leak #4
Diagram Here
Object moved
Great response. Hooked him up!!!!
Thanks for the info guys. I was pretty sure that I was going to be able to get at the outer one by pulling the cover off but wasn't sure about the inner one. Once again thanks for the help.
2012 CATERPILLAR 279C2 SKID STEER (A51246)
2012 CATERPILLAR...
UNUSED CFG QK18R EXCAVATOR (A51247)
UNUSED CFG QK18R...
2022 Ford Explorer SUV (A51694)
2022 Ford Explorer...
2017 HITACHI ZX350LC EXCAVATOR (A53426)
2017 HITACHI...
20" Sea Container (A47384)
20" Sea Container...
UNUSED FUTURE HYD MINI EXCAVATOR HEDGE CUTTER (A51248)
UNUSED FUTURE HYD...
