massey ferguson 85 question
   / massey ferguson 85 question #1
47champ
Circleville, Ohio
Massey Ferguson 85
I just purchased a M.F. 85, I have a problem that I am sure is operator error. While using the bush hog, the P.T.O. stops working at times. It happens when going around in a turn, or going uphill. Can someone please shed some light on this problem for me ...Thanks...Mark
   / massey ferguson 85 question #2
Is it possible there is a seat safety switch that is affected by your weight shifting?
   / massey ferguson 85 question #3
Not a seat switch on this old girl. Perhaps the slip clutch on your cutter needs adjustment. Can you verify the PTO shaft actually stops turning?
yes, Dieselsmoke, the shaft stops turning. I can then move to a flatspot or straighten out the turn, after fiddling with levers it starts back up.
   / massey ferguson 85 question #5
Check th fluid levels in the tractor. Sounds like it could be low on hydraulic oil.
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52128)
2022 Down2Earth...
CAT 973 (A47384)
CAT 973 (A47384)
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
1998 CATERPILLAR TH103 TELESCOPIC FORKLIFT (A51242)
1998 CATERPILLAR...
2011 Nissan Maxima Sedan (A50324)
2011 Nissan Maxima...
2016 Mercedes-Benz GL-Class SUV (A50324)
2016 Mercedes-Benz...
