MASSEY FERGUSON 65
   / MASSEY FERGUSON 65 #1
tthopskin@yahoo.ca
madoc ont 30 t years
and i just got a 580 c case backhoe real good shape got another kubota 2100 .. 2 - 684 IH 2 -8 N Ford had B275 IH MF # 50 work bull MF 35 all redone 65 mf 1750 kabota
MASSEY FERGUSON 65 . this is the best starting tractor i own :thumbsup: its diesel with multy power ...the darn thing is just about made me nuts .. i have split this tractor 4 times now and it still leeks oil from the rear end into the clutch housing , i put new seals then a new gear a new cross over pipe this time i put a new gasket under the power divider box and it still leeks .. i dont have a problem splitting the tractor 45 min and its in half ... it just what could be making it leek every thing is new .. any one ever had a pig like this to work on :confused: if you worked one one let me know what it is thanks ..
   / MASSEY FERGUSON 65 #2
Sometimes oil is forced past a seal by air pressure after some use and it gets hot. Does the rear end have a vent somewhere, and is it clear?
Bruce
   / MASSEY FERGUSON 65 #3
yeah, crankcase vent could be restricted. being older, does it have a lot of blow by? had a massey 35 for 28 yrs & over time it started huffing & seals began to leak. something i had to live with. good luck
   / MASSEY FERGUSON 65 #4
Have you replaced the seal rings for the multi-power circuit on the trans input shafts. There are oil passages through the shafts from the multi-power valve that operate the multI-power clutch. Sometimes the shafts are worn where these seal ring seat that even new ones do not seal and shafts and gears need to be replaced. Try running in low multi-power for a while and see if the leak is still there. If not it is likely these seal rings. Running in low multi-power there is no oil pressure to these rings since It is after the multi-power valve
2012 MACK CHU613 DAY CAB FLAT TOP ROAD TRACTOR (A51243)
2012 MACK CHU613...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
2008 Ford F-350 Altec Service Truck (A50323)
2008 Ford F-350...
2014 KENWORTH W900 MID-ROOF SLEEPER (A50854)
2014 KENWORTH W900...
2011 GENIE GTH-5519 (A50854)
2011 GENIE...
