Massey Ferguson 65 rear hydraulic problem
   / Massey Ferguson 65 rear hydraulic problem #1
JKDmo06
Fulton, MO
Massey Ferguson 65
I just purchased a Massey 65 and added a rear remote kit. I used the factory diverter valve that bolts onto the top of the transmission housing and when it's in the vertical mode the three point linkages work fine. I plumbed the top port into the positive port on a double action spool valve, then from the out on the spool valve into a quick connect fitting. I did the same thing with the return line. When I move the lever on the valve there is action in the lines but there isn't enough power to really do anything. Any suggestions on what I'm doing wrong?
   / Massey Ferguson 65 rear hydraulic problem #2
Maybe internal three point linkage is shutting pump off when lift arms raise? Must block them down OR place draft control lever at top of quanrant to keep pump on all the time for external valve use. Also remember that hydraulic pump is not high volume, maybe 4-5 gallon per minute when newer tractors have 10-20 or more.
1975 Chevy C60 Grain Truck (A50514)
1975 Chevy C60...
Whiteman Concrete Trowel (A47384)
Whiteman Concrete...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
ST225/75R15 Tires (A47384)
ST225/75R15 Tires...
Kubota SVL95-2S Compact Track Loader Skid Steer (A50322)
Kubota SVL95-2S...
