Massey Ferguson 6290 gearbox issues
   / Massey Ferguson 6290 gearbox issues #1
MasseyBoy390
johannesburg south africa
Massey Ferguson 390 & 6290
Hi There,
Please please please could somebody help me out, I recently bought a second hand MF6290 from a guy, he said he was using it and it started slowing down and eventually stopped moving. He replaced the clutch and all and still no movement, he then continued on to have the dynashifft lever removed as he thought it might be that...I then bought the thing at the time as he told me it was just the clutch (I thought no biggie to replace)...took it to the dealer, they said clutch is fine...had the ECU under the cab checked and found a fault, was repaired but still no movement....upon start up the lights on the dash light up and then go off, there's no High or Low indication light on nor are there ranges A-D lights showing...I am yet to check the solenoids by the gearbox itself...please could someone advise me what to do as the dealership and I are clueless... could it be the BOC switch thats busted or something? also do I need to recalibrate it for the new clutch? if so, how do I do so?
Thank you in advance!:)
   / Massey Ferguson 6290 gearbox issues #2
Suppose you have checked fore fault codes with a diagnosis computer?
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
WOODS DS8.30 LOT NUMBER 52 (A53084)
WOODS DS8.30 LOT...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
RoGator RG1300C Air Max Precision 2 Spreader (A53342)
RoGator RG1300C...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
2020 Ford F-250 Pickup Truck (A51692)
2020 Ford F-250...
