Massey ferguson 35 gas deluxe hydraulic issues
   / Massey ferguson 35 gas deluxe hydraulic issues #1
Rhawkins1
scottsville
Massey ferguson 35 gas De luxe 1959?
I think I have overfilled my transhydro and now have hydro oil in my starter
looking for info on how serious my issue is
it is about a 59 era Massey Ferguson 35 gas deluxe 2 stage clutch
I was using tractor and everything seem to work fine
then it acted like it was sluggish to restart
I noticed on the front of starter housing a weeping of oil
oil was also weeping form brake pedal inputs and clutch pedal inputs and main joint on frame weeping
I removed starter motor and about a cup of oil ran out
I believe it to be the hydraulic oil... I used the 80/90 mineral from tsc gl1
I looked at my stick and found it to be way over the line
I had topped of previously as it had been low and sure thought I had it on the mark
I have since drained excess oil but the starter appears to be dead... tractor is converted 12 volt
I would like to know what seals if any separate the starter and flywheel from the hydraulic well
is it merely overflow or does it need a breakdown and service/replacement
I believe the starter will need a rebuild as I tried it several times before all electrics went dead
Neighbor said I could clean it... I want to rebuild it and reinstall if fluid issue is just overflow
Battery still has a charge 12.5+or-
Any input would be great thanks in advance
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
Test Button (A47384)
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
2023 JOHN DEERE 50G EXCAVATOR (A51242)
2023 JOHN DEERE...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
