reco31
- Joined
- May 25, 2014
- Messages
- 27
- Location
- Cochrane, Ontario
- Tractor
- Zetor 7745, MF 35, MF 175, Fordson Major
Hello guys and gals, I知 trying to get my grandfathers 35 running properly. Bought new in 61 with the Perkins, used all summer to rake but started running like crap awhile ago, fuel knock under load, stalling after running for awhile and having to pull it to start, otherwise it would just crank and crank. Replaced lift pump, filters and the injection pump but it痴 still a job to start. Bled and bled from tank all the way to injectors but still not running properly. We get it running and find foam from middle injector line at injector when cracked. Shut it down, pull off line and foam keeps coming back out of injector? Is the injector worn or stuck open a bit? Could compressed air from cylinder be forced back through injector and into pump? Also #3 injector is leaking around head. Any insight would be greatly appreciated. Thanks
