Massey Ferguson 2860E cranks but won't fire
   / Massey Ferguson 2860E cranks but won't fire #1
TractorTech
Elite Member
California
Ford 7710, Ford 550, Ford 1910, Ford 4430, KD Forklift, Ford LGT17H, New Holland L255 Skidsteer
I have a 2021 2960E with about 122 hours on it. It ran fine a couple of days ago. I went to start today and it just cranked. The electric pump is working and has plenty of fuel down to the pump. No codes showing. The fuel cutoff doesn't seem to be opening.
Any help would be great.
   / Massey Ferguson 2860E cranks but won't fire #2
Are you getting power to the fuel cutoff? If not check the fuse. If you're getting power but it's not opening it may have died and need replaced. Or it may just be stuck. Try tapping it a couple times with a screwdriver handle.
That is what I was looking at originally. It belongs to a neighbor and he said he had a blown 5 amp fuse, but didn't know which one as he took them all out to test at his shop. He replaced the fuse, but no luck. When I arrived, I started to check the fuses, but he said he replaced the bad one.
Just talked with him and he found a blown 5 amp fuse, replaced it and now it runs.
The problem I had was that it is a common rail system. There are four 5 amp fuses that are labeled ECU... I wasn't sure if this was a regular fuel cutoff or not. It has a very, very small fuel passageway.
On top of that, Massey Ferguson calls it a "Suction" and sells it for $621.
I trusted the neighbor and know better. When I am on to something, follow through.
2006 INTERNATIONAL 9400I SLEEPER (A53843)
2006 INTERNATIONAL...
1999 FORD F-450 SUPER DUTY SERVICE TRUCK (A54756)
1999 FORD F-450...
2019 POLARIS RANGER XP1000 RTV (A51406)
2019 POLARIS...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
5' S/A CART (A52706)
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A54607)
2007 POWERSCREEN...
