Massey ferguson 2635 hydraulic issues
   / Massey ferguson 2635 hydraulic issues #1
Whimpy58
Massey 2635 loader and bucket curl leak down constantly. The three point arms will fall randomly, may or may not lift back up if they do they’re slow, sometimes have to kill the tractor put the remote all the way up soon as tractor starts the arms raise fast like they’re supposed to. Three point arms will fall if you idle the tractor up but will raise right back up as soon as it goes back to idle.
   / Massey ferguson 2635 hydraulic issues #2
Do the loader and three point run off same pump
If it has internal pump for three point should be a little cover on bottom of differential the screen for the pump is accessible under that cover if it gets plugged up enough
Three point will raise at idle but when you rev it creates a vacuum and pulls control to dump oil
No pressure. have to drain trans oil
Or get a bath
My understanding the 3pt has it own pump. The loader and rear remotes are on a separate pump
   / Massey ferguson 2635 hydraulic issues #4
If pump is inside they both suck off same screen in trans
Does your loader have front mounted pump off crank pulley or do hoses come from top cover
And you have to put it in constant pump
The issue would be the same on loader no oil so full of air
FIRESTONE 20.8R42 REAR TIRES WITH WHEELS (WHEELS FITS GENESIS TG-T8000 TRACTORS) (A52748)
FIRESTONE 20.8R42...
Peterbilt 377 Semi-Truck (A52748)
Peterbilt 377...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
