Massey Ferguson 210 parts needed
   / Massey Ferguson 210 parts needed #1
beesink
anna, il
MF
I have a problem with my MF210, which I expect is a piston rod. Haven't broke it down yet - the engine is stuck. No water in oil, so hopefully no block damage.
The engine is a solid block, so rebuilding would be complicated and expensive due to high parts prices ($175 for a standard piston for example). MF no longer stocks them so they must come from an importer. Over sized pistons are not available. The engine was only used for a short time so there are not a lot out there in the US.
Does anyone out there have one for parts? It has the Toyosha 1.3L - two cylinder diesel. Similar to AC 5020 and Hinomoto E23. The tractor was built in Japan by Hinomoto.
   / Massey Ferguson 210 parts needed #2
My dad also has a MF 210 and if the price was right I'd like to have a parts tractor.
His needs a manifold. It's been welded up and now has a straight pipe on it and boy is she loud.
I think a MF 205 has same block
I would consider trading it for a small tractor that still has available repair parts (like a MF 35 or similar).
I would not mind if it needs some work as long as it is running.
The 210 is a nimble little tractor with plenty of power for the weight.
Until I break it down I will not know how extensive the engine damage is.
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
2023 Vivid EV Golf Cart (A51694)
2023 Vivid EV Golf...
2013 FREIGHTLINER CASCADIA 125 DAY CAB (A52141)
2013 FREIGHTLINER...
John Deere 348 Square Baler (NICE) (A50774)
John Deere 348...
2010 Wacker Neuson Light Tower (RUNS) (A50774)
2010 Wacker Neuson...
Case-IH 165 Puma (A50120)
Case-IH 165 Puma...
