Massey Ferguson 202 Steering
   / Massey Ferguson 202 Steering #1
Jonnyzebra
1948 8n 1979 140 HiClear
I am trying to help an older friend with the steering on his 1968 202. It has the required pressure from the pump but the steering seems to get tight after a few minutes of running. Any suggestions on what to look at or procedure would be helpful. Thanks Jon
   / Massey Ferguson 202 Steering #2
G,Day .
try jacking up the front of the tractor so that the wheels are of the ground and see if the steering is tight in the king pins maybe need greasing.
Hutch.
   / Massey Ferguson 202 Steering #3
try changing the power steering filter. if there is a little water in the system it stands around the filter until pressure builds up , then clings to the filter blocking pressure from getting thru
1997 Cat 953C Crawler Loader (RUNS) (A50774)
1997 Cat 953C...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2012 Volkswagen Jetta Sedan (A50324)
2012 Volkswagen...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
1965 Great Dane 40' Flat Bed Trailer (A50121)
1965 Great Dane...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
