Massey ferguson 175 mixing
   / Massey ferguson 175 mixing #1
Jervontae
Atmore Al
Duetz D6006
Thinking about buying a massy F 175 and the guy said that the transmission fluid is mixing in the engine oil is this possible if so what are the causes ??? Or what could be mixing with the oil ??
   / Massey ferguson 175 mixing #2
Sounds strange, on English build tractors there are no point where that can happen. Might be power steering fluid.
How could I check for that and I thought it sounded strange also
Someone told him it was transmission seals but I don't see that you have to break the whole tractor in half for that
   / Massey ferguson 175 mixing #5
You must splitt it if the seals on the transmission is gone, does it leak? Check that the weep hole is open in the bellyhousing.
   / Massey ferguson 175 mixing #6
At no point would the fluid from the trans or rear end have a path to get into the engine, even a hydraulic fluid cooler would only have lines running to the front and that would be external to the engine. IF the power steering pump is leaking into the engine it would be some sort of seal at the front of the pump where it a shaft is driven by a gear off the engine (if it is an engine mounted pump).
   / Massey ferguson 175 mixing #7
I have MF 175. It is the power steering pump It Took me awhile to figure out why tractor made oil. I rebuilt it still leaked. Bought new one works fine.
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
2016 Ford Taurus AWD Sedan (A50324)
2016 Ford Taurus...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2004 Mustang Deluxe Convertible (A50324)
2004 Mustang...
