Massey Ferguson 175 Hydraulic Problems
   / Massey Ferguson 175 Hydraulic Problems #1
misfit125
Halifax, NC
MF 175
What should the pressure be and where do I connect the gauge to check pressure on a MF 175? The lift raises very slow and immediately goes down when engine shuts down.
   / Massey Ferguson 175 Hydraulic Problems #2
If you want to check the pressure, either plug a hyd gage into the work ports QD's, or install a hyd gage in the IN port of the loader valve and you can check everything hyd .
The piston seals could be bad.
The valve could be bad.
The pump could be bad.
A relief valve could be open.
A flow and pressure check would be the best thing to do.
Pressure might be in the 2000 psi area with a good pump.
2005 Mack Vision Semi Truck (NOT RUNNING)(TITLE) (A50774)
2005 Mack Vision...
New Holland 824 2 Row Corn Head (A50774)
New Holland 824 2...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
Payment Terms (MUST READ) (A50775)
Payment Terms...
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
