steve42rich
I had water in the oil so i pulled head to replace gasket and found the first piston close to radiator with lots of slack 3/16 or more the other 3 pistons are tight so what would cause the engine not to wear equal and what do i do now pull motor and rebuild the sleeve on that cylinder is realy thin the other 3 are thick i gues it is possible to just sleeve the 1st cylinder the sleev also has slipped down a little
