Massey Ferguson 1529 Front Hub to Axle Seal Leak
   / Massey Ferguson 1529 Front Hub to Axle Seal Leak #1
hb8959
West Papm Beach, FL
Hi,
This is my first post here so please bear with me if I do not have all the terminologies correct. I have a leak on the passenger side front axle where the axle pivots when you turn the steering wheel. I have a Massey Ferguson 1529 with 240 hours and it is just out of warranty. I researched the thread, and found what I thought was the solution to fix the problem, but it was for a Massey Ferguson 1533 posted by a member and the heading was "Hub to Axle Seal Job complete on a 1533, Photos". My problem is identical to this. Unfortunately the 1529's do not have that cap at the bottom. It is one complete housing. From the schematic in the Agco parts book, it should be a snap ring, a bearing, another snap ring, another bearing, and then the seal. After I found out that there is no cap, I proceeded to take the hub out, but I do not know how to proceed further.
Any help anybody could provide, will be highly appreciated.
   / Massey Ferguson 1529 Front Hub to Axle Seal Leak #2
Rise from the dead thread! Did you get this figured out? My 1532 is like yours
   / Massey Ferguson 1529 Front Hub to Axle Seal Leak #3
Another resurrection. Were you able to change your seal on the front wheel? Mine leaks also.
   / Massey Ferguson 1529 Front Hub to Axle Seal Leak #4
I did, I followed this thread. The only difference on mine is I don't have the cap at the bottom. I had to pull the hub face (for lack of a better description) then the retainer clip was accesses from the side. A bit of a challenge to get back on but not hard, just the angle I was working at. If I can help anymore, just ask.
http://www.tractorbynet.com/forums/...rating/129202-hub-axle-seal-job-complete.html
Miles read : 112,969 (A50323)
Miles read ...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
2017 John Deere HPX615E Gator Utility Cart (A51691)
2017 John Deere...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 JOHN DEERE...
Krause 8200 Cushion Flex Disc (A52349)
Krause 8200...
Yale 3,500lb Electric Forklift (A51691)
Yale 3,500lb...
