Massey Ferguson 1528 Final Case Install
   / Massey Ferguson 1528 Final Case Install #1
cmb1998
Hello,
I've got a MF 1528. It ate a snap ring (#15) on the front axle. I tore the unit down, cleaned everything up, got the replacement part from AGCO.
How do I get the final case LH (17) to install over the Final Case (1A)? There are two bearings (14/13) in 17 (inside what is shown as 22 - this is the back of 17) that slide up over 1A. They are locked into place in 17, and for the life of me can't them slide back up over 1A.
Any help?
   / Massey Ferguson 1528 Final Case Install #2
I seem to remember seal #12 is a 2 piece seal. Did you remove the inner part from the final?
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A61307)
2024 Kubota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
UNUSED FUTURE FT-ZDQ160 110V CONCRETE VIBRATOR (A60432)
UNUSED FUTURE...
2012 DOOSAN G25KW GENERATOR (A55745)
2012 DOOSAN G25KW...
