Massey Ferguson 1466 loader nimco 2s-40272 help
   / Massey Ferguson 1466 loader nimco 2s-40272 help #1
Ram0689
Massey Ferguson 1440V
Hello all
New to the tractor and forum.
I have a Massey Ferguson 1440V with a 1466 front end loader and the Nimco control valve is leaking.
I have the o ring and seal rebuilding kit but need some help with doing the job or some instruction on how to get it apart to replace the o ring and seals.
I have taken the joy stick and ball studs off and now want to get to the meat of it but again need some guidance on how to get the rest apart without having
to take it all apart. Any help will be greatly appreciated.
   / Massey Ferguson 1466 loader nimco 2s-40272 help #2
On most valves there is a cover plate goes over the spool that holds the seals in place. Typically you just remove this retaining plate and replace the O-rings under the retaining plate.
No need to remove the spools from the valve.
End opposite the linkage will have a centering spring assembly of some type that will have to be removed.
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
(2) UNUSED 7000# DROP AXLES W/ BRAKES (A51247)
(2) UNUSED 7000#...
Lot of 2 Caterpillar Loader Tires (A51691)
Lot of 2...
(APPROX 19) 4" X 10" X 49 1/2" THICK I BEAM (A51247)
(APPROX 19) 4" X...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
