scott123456789
Bronze Member
Seemed pretty clean after 40 years....
Thinking this may have had something to do with the levers not functioning properly.
The OSHA approved rig that made everything possible. Guys aren't lying when they say the lift cover is heavy!
Does the hydraulic fluid look terrible? I believe it has at least 600 hours on it if not a bit more.
The ram piston should be moderately compressed the the ram rod dangling loose correct?
The spring binding here may have been the culprit, I accidently let the spring come off but on reassembly the position lever moved the pump relief valve...
