Massey Ferguson 1240 4Wd sticky clutch
   / Massey Ferguson 1240 4Wd sticky clutch #1
Streak
Stroudsburg, Pennsylvania
1240 Massey Ferguson
I have a model year 2000 MF 1240 4WD with 800 hours on it. Nice little tractor, but seems to have a sticky clutch when warmed up thoroughly. sometimes when I depress the clutch it will stay depressed momentarily, and then release all at once. It does not do it all the time, but just often enough to be annoying. Acts like the T/O bearing is hanging up on its shaft. Is there a lube point I am missing? Can I access it to lube it? This tractor has the synchronized shuttle to the left of the steering wheel for forward and reverse. I have to depress the clutch to reverse or go forward. Other than this there are no other obvious issues. GREAT little machine. Any and all suggestions appreciated!! thanks
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
Cat TH407C Telehandler (A53472)
Cat TH407C...
YOKOHAMA - GALAXY 16.9-24 DIAMOND BUTTON TIRES (A53472)
YOKOHAMA - GALAXY...
2025 New/Unused 72in Skid Steer Brush Cutter (A51573)
2025 New/Unused...
