Massey Ferguson 1135 3 PTH hydraulic
   / Massey Ferguson 1135 3 PTH hydraulic #1
Chodge22
Forest City, NC
Massey Ferguson 1135, Ford 4610, kubota 4330
Can't get the hitch to go up or down. Power steering, PTO, and AUX HYD's work fine but I have no pressure to the hitch. What do I need to check?:confused:
   / Massey Ferguson 1135 3 PTH hydraulic #2
I'm a newbie.
On my tractor, under the seat, between my legs, there is a control dial, which I think controls the flow to the 3pth. If it is closed, the hitch will not move. Some leave it all the way open, some leave it in the middle setting, and some use the dial to control the hitch movement speed regularly.
If you have an operation manual, it should have a section about it.
Hope that helps.
   / Massey Ferguson 1135 3 PTH hydraulic #3
check the linkage connection behind the cab above the aux. ports. the bolt on that connection rattles loose
I have checked those and they were fine. Where would any valves be located for the hydro's on the hitch? I hope it is not something under the rocker housing that will be a tough one to fix.
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
2005 FREIGHTLINER COLUMBIA SLEEPER (A54313)
2005 FREIGHTLINER...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
