Massey Ferguson 1010 3 point issues
   / Massey Ferguson 1010 3 point issues #1
Mascase
Kyle, TX
Massey Ferguson 1010 and Case VAC
Hi I have just acquired a Massey 1010 with just a 3 point hitch however the 3 point does not lower, raise or hold load at all. It originally had water in the hydro fluid and I drained and put new filter on. I checked for flow on pump outlet and it flows good. Under the seat I opened the screw and blew compressed air and 3 point lifts good doing that so I'm guessing piston seals are good. Relief valve looks clean but I don't know for sure if it operates. Any help would be greatly appreciated.
   / Massey Ferguson 1010 3 point issues #2
Sorry I didn't see your post earlier.
If you haven't already solved the problem, I've attached the section of the service manual for the MF 1010 hydraulics. It should help with your troubleshooting.
  • MF Service Manual Hydraulics.pdf
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
2021 POLARIS XP1000 RANGER (A51222)
2021 POLARIS...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2011 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2011 MACK GU713...
