Massey charging help!!
   / Massey charging help!! #1
rdttwo
Seymour, East Tenn.
1987 Massey ferguson
. I have a charging problem with system on my circa 1985 MF 1020 2WD. I think the alt. is fine ( probably), BUT NOT SURE OF IT. I have a new battery installed, voltage across the terminals is about 12.8v,engine off. With the engine running and no access. turned on, voltage across the batt. stays about 16.8 to 17 volts. If I turn all the lights on, voltage across the batt. drops to 15.5 volts. This far too high, it's supposed to be around 14volts. No parts available from Massey dealers (sigh). Any advice about what I can do would greatly appreciated. Perhaps a conversion to an auto alternator with integral reg. ???
   / Massey charging help!! #2
Does yours use a delco alt? Ytmage has some vregs under the 1020if your original reg was a 1119507
Otherwise see if arrowhead electrical products is in business.
Also check just tractorparts
In the end if the salt or very is bad, a delco 10si is 30$ from auto zone ..
This is Hitachi unit unit soundguy,the rest of your post was really garbled
   / Massey charging help!! #4
Looks readable to me?
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
(APPROX 24) 2" X 6" X 60" CHANNEL IRON (A51247)
(APPROX 24) 2" X...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2005 TerraGator 8104 (A53472)
2005 TerraGator...
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A51694)
2017 Nitro Z 19ft...
