massey 65 deseil
   / massey 65 deseil #1
gell
bemidji
massey ferguson 65
I have massey 65 that needs brakes, and one of the oil seals on the end of the planitary gear leaks bad. Can some one tell me is this a job most anyone can tackle, special tool needed, etc Also where might be a good place to order parts, maybe a kit with all needed gasckets etc. to do a brake job. Thanks for any and all info. gell
   / massey 65 deseil #2
G,Day gell.
If you are talking about the seal NEAREST the wheel yes you need a press and the planetary bearing will need to be preloaded ,before pulling the axle assembly out ,with the tractor sitting on level ground give the rear wheels a good rock like stand facing the wheel and put both hands on the top of the tyre and give the tractor a good rock ,you will most likely hear a CLUNK this is the tapered roller bearings loose inside so after stripping ,cleaning and fitting a new seal and possibly new bearings the assembly must be preloaded which require a certain ammount of knowledge and special tools I would suggest taking the complete axle assembly to your local Massey dealer.
thats all the help i can offer.
bemidji??sounds like victoria??.
happy Days .
HUtch.
2016 POLARIS RAZOR XP1000 (A51222)
2016 POLARIS RAZOR...
2014 VOLVO VN SERIES DAY CAB (A50854)
2014 VOLVO VN...
2017 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2017 Ford F-450...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2022 INTERNATIONAL MV607 26FT BOX TRUCK (A51222)
2022 INTERNATIONAL...
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
