Massey 4225 Four Wheel drive
   / Massey 4225 Four Wheel drive #1
chd1973
I have a MF 4225 which appears to be stuck in four wheel drive all the time.
Anyone had the same or know how to sort the problem?
Thanks in advance.
   / Massey 4225 Four Wheel drive #2
Is your 4wd mechanically or electricly engaged?
It is electricly engaged.
   / Massey 4225 Four Wheel drive #4
Could be as simple as a fuse or switch. I'm pretty sure those took hydraulic pressure to release the 4wd. So the switch opened the valve to apply pressure to release the 4wd and allow it to run in 2wd. I would check the fuses then switch. If you have a service manual it should show where the actuation happens, you could check to make sure you're getting power there next if the switch is good.
1262 (A50490)
1262 (A50490)
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
TRUCKING INFO (A50775)
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
