massey 35 with single hose hydraulic remote?
   / massey 35 with single hose hydraulic remote? #1
jiminpa
Bronze Member
northwest pa
massy 35 diesel kubota l3400
mine has a single hose(bull?) remote. can i remove this since it isn't used and what do i replace it with? or can i just remove the hose and plug it off?
   / massey 35 with single hose hydraulic remote? #2
If memory serves me well. the MF135 like its predecessor had just the one lift lever. And if I remember, if you had a tipper cart connected, the cart never started to lift until the draught arm had risen to as high as they could go before oil started to go to the lift ram on the cart. If that is the case, then when the arms are lifted, full oil pressure will at the same time be trying to go through the auxiliary oil pipe. Again to answer your question, I see no reason the pipe could not be removed, as long as it is capped or plugged to take full hydraulic oil pressure. Saying all of this, is the fact there is a pipe there such a problem and might it at a later date be useful.
UNUSED FUTURE MINI EXCAVATOR HYD WOOD DRILL (A51244)
UNUSED FUTURE MINI...
2018 International WorkStar 7400 T/A Dump Truck (A50323)
2018 International...
2014 Nissan Frontier Ext.Cab Pickup Truck (A50323)
2014 Nissan...
2017 Dodge Grand Caravan SE Van (A50324)
2017 Dodge Grand...
2015 CATERPILLAR 289D SKID STEER (A51242)
2015 CATERPILLAR...
Wolverine Quick Attach 80' Bucket (A50514)
Wolverine Quick...
