massey 35 hydrollic 3 point lift
   / massey 35 hydrollic 3 point lift #1
1tnmtnman
Sugar tree,Tn.
massey 35 special
gear oil got added to trans now the 3 point will not lift have taken top cover off and pump is working but not shooting oil out of casing how can i check the pressure being delivered to the cylinder and how can i find out what the pressure range should be , the feed tube to the cover came out with the cover thinking I may be able to check cover and piston with air over oil (fill cyl. and apply air behind)
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2016 FREIGHTLINER...
Toro Workman Utility Cart (A51694)
Toro Workman...
Car Lift (A50121)
Car Lift (A50121)
LandPride RCF2072 (A50120)
LandPride RCF2072...
BAUER ATD-750 VERTICAL HYDRAULIC PIPE HANDLER (A52472)
BAUER ATD-750...
1999 Peterbilt (A50120)
1999 Peterbilt...
