Massey 271 ? about power steering
   / Massey 271 ? about power steering #1
purplewg
I have a 271 XE Massey and the other morning I went out started her up and turned the steering wheel and the front tires/wheels stayed straight. I shut it down, checked the hyd fluid and it was full. It was a bit cold for my area but not freezing. I let it idle for a few minutes while I went to get the manual to make sure there wasn't a separate steering reservoir. There isn't. I shut it down and rechecked the hyr fluid. I noticed I could turn the steering wheel without the engine running which isn't good. I started it back up and it worked fine.
A couple days later I had the same deal but I just let it idle for a minute or two and it started working just fine. The first day I had let it idle much longer and still no steering but it eventually did start to work.
There is a hydraulic cylinder up front by the radiator that turns a pitman arm configuration and I could see it was not working when I turned the steering wheel so either it is going bad or it wasn't getting good flow I would suspect. There are no wet spots or leaks around this cylinder.
Any opinions on this?
   / Massey 271 ? about power steering #2
Have you checked your steering filter.
No, I can't say that I did. When I looked in the manual I didn't see any mention of one on it. I do have the big hydraulic filter under the right side running board. I will certain take another look.
Fired it up yesterday and it worked right away. Seems to be cool related.
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52748)
Kuhns AE10 Small...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A51691)
2022 McConnel...
2013 INTERNATIONAL PROSTAR (A52472)
2013 INTERNATIONAL...
Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A51691)
Godwin CD150M 6in...
Massey Ferguson 9250 (A52748)
Massey Ferguson...
CONTACT INFO (A53084)
